landlord11
Aug 01, 2017Follower
Extremely slow performance with Orbi satellite
Hi, I have owned an Orbi system since last November (single RBR50 and RBS50) and have found it to be very reliable. Today I decided to install an Orbi setup for my mom (also RBR50 and RBS50).
I have the router setup as an access point, and it is working great. The satellite is connected and working, but I'm seeing extremely slow throughput when connected to the satellite.
To test this, I placed the satellite in the same room as the router. They are approximately 10 ft apart with a clear line of sight. If I run a speedtest while connected to the router via wireless I get ~70 Mbps. If I connect to the satellite via wireless _or Ethernet_ and run a speedtest, I get ~3.5 Mbps. Since it is slow over Ethernet I assume it is a problem with the backhaul.
I tried downgrading to 1.8.0.6 and did a factory reset but it didn't help on both units but it didn't help. Since then I upgraded the firmware back to the latest (1.12.0.18).
So, has anyone else seen such extreme slow speeds with the satellite? Or is it possible I got stuck with bad hardware and should exchange it?
Thank you!
Brian
- DarrenMSr. NETGEAR Moderator
Hello landlord11
Can you try to re position the satellite and test again or even move it close to the router to test.
DarrenM
Having the same issues for the past 3-4 months, Speedtest is slow and many timeouts when I ping even the local default gateway. Only seems to happen with the satellite unit and has become very frustrating to deal with this. Support has provided firmware betas that had helped in the past then the problem comes back. My house is only 2000 square feet!
- Having the same issue with the satellite for 3 months and it’s impacting things like my Wifi baby monitor, work and phone calls as well as smarthome devices which is unacceptable and false advertising!
Is a fix coming, I have the two unit configuration covering a 2000 square foot house and this setup is supposed to cover twice this square footage. The annoying thing is everything worked great for 5-6 months then all of sudden an issue. Support keeps giving me a run around with no real answer except they know something is wrong, I’m to the point I want to exchange my satalite but support at netgear is telling me that won’t fix the problem!
Well if that’s the case I won’t my $350 back so I can buy a product that works as advertised!
Ion
