Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Djzgfx
Dec 28, 2017Tutor
No one?
- michaelkenwardDec 28, 2017Guru - Experienced User
When everything else behaves as expected, it is hard to see how a router could cause this sort of thing. Maybe that explains the silence.
Have you checked its logs to see if it is blocking sites?
- DjzgfxDec 28, 2017TutorYep. No blocked sites. I know, this is such a weird problem.
- Kaelin_ReedFeb 12, 2018Initiate
Same problem.
Network speeds are fine.
Problems only with Instagram
