Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
michaelkenward
Dec 28, 2017Guru - Experienced User
When everything else behaves as expected, it is hard to see how a router could cause this sort of thing. Maybe that explains the silence.
Have you checked its logs to see if it is blocking sites?
Djzgfx
Dec 28, 2017Tutor
Yep. No blocked sites. I know, this is such a weird problem.
- Kaelin_ReedFeb 12, 2018Initiate
Same problem.
Network speeds are fine.
Problems only with Instagram
- Sellmetv2Feb 19, 2018TutorHad the same problem with my Netgear orbi wifi. By connecting to another wifi and then going to Instagram on that different wifi and then going back to the Netgear orbi Instagram worked again.
