Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Feb 19, 2018Guru - Experienced User
Is IPv6 enabled on the router? Disable it and test.
I would run a quick test as well, set WPA mode to OPEN. No security on the wifi temporarily. Test FB and other apps. Any changes?
WMM should be always enabled for wifi devices.
Try both radios.
Set Up to 300Mb on both radios, manual Channel 1, 6 or 11 on 2.4Ghz, any on 5Ghz.
WPA2 and AES only on both radios. Try WPA and TPIK only and see if thats possible.
Disable any bandsteering or mimo options under Advanced/Advanced wireless if seen.
Any other wireless near by?
What is the Mfr and model# of the ISP modems being used?
No issues seen on my NG Orbi currently.
