Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Galgomite
May 25, 2018Tutor
I have an Orbi/ Satellite combo and have been having similar problems. Most everything was fine but Facebook wouldn't load images. Switching to cellular data solved all problems. The solution that worked for me was to log into my router and manually reinstall the current firmware (downloaded from netgear's site) for the router and then the satellite. It hasn't been up very long, but as of now all Facebook-related issues (ok, the ones regarding loading:) have been resolved.
Galgomite
Jun 29, 2018Tutor
Update solution only lasted a few hours... same with disabling ipv6 filtering. I’m using gigabit fios and think the next step will be to try Verizon’s rental router:(
