Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
kinyan1123
Jul 01, 2018Initiate
I have exactly the same problem.
youtube, chrome ,every other app works except facebook and IG
I am using Orbi Mini Mesh system RBR40
please Help
- FURRYe38Jul 08, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem the Orbi is connected too? Built in router here by chance?
What devices are you having problems with?
Wireless or wired connections? Both?
What FW version are you using?
please Help- jimbojames79Jul 09, 2018ApprenticeI have the same problem. Well it's one of the many I have. It's bizarre because I get a notification but when I open the app it won't be there until I disconnect the WiFi. Am UK based on Virgin Media. Single router setup. Satellite makes my problems 100 times worse.
- FURRYe38Jul 10, 2018Guru - Experienced User
