Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
2BorNotOrbi
Aug 01, 2018Aspirant
Same issue here. FiOS, Actiontec MI424 router, Orbi RB50. Actiontec is in ridge with WiFi off. Everything is great except facebook and instagram. Tried some of the fixes mentioned, and nothing lasts for more than a couple hours.
All devices are up to date on firmware.
Aug 01, 2018Guru - Experienced User
Try this?
2. Unbridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then use the Orbi router in Router mode.
Or try 3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, and configure AP mode on the Orbi router. Don't use DMZ on the modem for this option.
- kinyan1123Aug 01, 2018Initiate
Finally I got this fixed.
Disabling IvP6 do the tricks.
Seem facebook app have problem with this setting- FURRYe38Aug 01, 2018Guru - Experienced User
IPv6 should be disabled by default unless you have an ISP that supports IPv6 natively.
Glad you figured it out.
