Djzgfx
Dec 28, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Feb 11, 2019Guru - Experienced User
Seems to be known issues with Circle. I recommend disabling Circle until next FW upate. Users can check into new Beta FW if they want to give this a try:
Richo666 wrote:
Hi all,
For those of you that have not worked this issue out, it seems to be the circle filter if you have parental controls enabled..no matter what level it will block facebook and instagram.
I turn circle filter back on and issue re-appears.
Hope this helps you all enjoy ...regards richo
Richo666
Feb 11, 2019Tutor
Just an update on the circle issue which is not really an issue at all ive found.
When selecting a filter make sure that safe search filter is allowed.This will allow facebook and instagram to work as intended.
Kind regards
Richo
