Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
becktoven
Mar 17, 2019Aspirant
Was having same problem with IG & FB not loading pictures/posts etc. Changed IPV6 setting to OPEN from SECURED and it fixed the problem... at least immediately it did... I'm wondering whether or not that is prudent and what are the risks of changing that setting? Any help on that is appreciated!
Mar 18, 2019Guru - Experienced User
Do you mean NAT Filter? Theres only IPv6 enable and disabled....
You can run NAT Filter OPEN and it's a different way to allow data to pass thru the firewall.
- becktovenMar 18, 2019Aspirant
Under the 'ADVANCED SETUP' tab in the 'ADVANCED' settings, I click on the IPV6 option. At the bottom of that page it says:
IPv6 Filtering secured open
I changed the setting to OPEN from SECURED and that worked for the IG & FB problem. I confirmed (with the kids of course because I don't use either of them) it is still working this morning after changing the setting last night.
- FURRYe38Mar 18, 2019Guru - Experienced User
Do you have IPv6 natively supported from your ISP? If not then you can disable IPv6 all together, if you do then you can use IPv6 with Filtering set to OPEN if this clears up the issue for you. If you don't seem to use IPv6 then you can disable IPv6.
Yes, it's supported and changing the value to OPEN from secured fixed the problem with IG & FB. My question to the community was basically, what kind of risk is there changing the value from SECURED to OPEN for the IPv6 Filtering setting???
