Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
Mr-Han
May 26, 2019Initiate
Hi everyone,
I think i found the solution. It is quite simple actually. After many hour of talking to my ISP, I realize it is not the ISP problem but the Orbi defaults setting. Go to advanced set up, then IPv6 change that to pass through so it uses the ISP default one vs Orbi default setting. I am not an network expert so I don’t know the implications of me setting up this way but both FB and Instagram work perfectly right after me doing so.
My set up is:
Shaw Canada router on IP Passthrough mode.
Orbi Router mode.
My set up is:
Orbi Router mode.
