Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
michaelkenward
May 27, 2019Guru - Experienced User
Mr-Han wrote:
I think i found the solution. It is quite simple actually. After many hour of talking to my ISP, I realize it is not the ISP problem but the Orbi defaults setting. Go to advanced set up, then IPv6 change that to pass through so it uses the ISP default one vs Orbi default setting.
Neat.
If other people can confirm that this works for them, this could be marked as Solved.
