Djzgfx
Dec 27, 2017Tutor
Facebook and Instagram Intermittent Loading
Hello, I’m having the exact same problem on my mobile devices as this post that got zero comments https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Problems-with-Facebook-and-Instagram/td-p/4971...
May 28, 2019Guru - Experienced User
The IPv6 setting is depending upon if your ISP supports native IPv6 thru the ISP modem. If your ISP doesn't support native IPv6 then the IPv6 setting on the Orbi can be disabled.
