pjJim
Jul 29, 2018Tutor
Facebook using wifi
Phones cannot connect to Facebook using wifi from my orbi. Is there a special setting?
Jul 29, 2018Guru - Experienced User
Shouldn't be. Mine connects iphone 6sP.
What phones do you have?
What Mfr and model# ISP modem is the router connected too?
Any access controls or circle enabled on the router?
- pjJimJul 30, 2018TutorPhones are Samsung s7 and s9+. Also a Samsung tablet. They work fine on wifi elsewhere- for example at starbucks.
Note: wifi worked fine using prior router a netgear nighthawk. So not a phone problem.
Parental controls are off on router.
