dgarbacz
Mar 29, 2018Aspirant
facetime freeze on satelites
when using facetime on the secondary sateliite units after 5 min the unit completely freezes and the phone or ipad becomes useless. nothing will work. they are both rbk50 as well. this happens ev...
Mar 30, 2018Guru - Experienced User
What FW version are you using? Give the Beta a try at the top of this forum thread there is a link.
What iOS are the devcies using?
What channels are you using?
What security modes are you using? Try WPA2 and AES only.
Disable IPv6, MIMO, Daisy Chaing and Fast Roaming if you have these features and try facetime.
dgarbacz
Mar 30, 2018Aspirant
thanks, the controls via the orbi app are virtually non extistant. FV 2.1.1.18 which unit claims is the latest.
it only happens on the satelites.
using wpa2-psk the only option
there is noncontrol i can see for your other suggestions.
my multiple iphones and ipads are all running the current ios .
