SLK-Purdue's avatar
SLK-Purdue
Luminary
Apr 21, 2020
Factory Reset Backhaul Passphrase?
Am I correct that a Factory Reset will reset a default backhaul wireless passphrase?   Here is my situation.  I have a RBR50 and RBS50s that were all installed after a factory reset.  All is workin...
  • FURRYe38's avatar
    Apr 21, 2020
    Is Daisy Chain enabled? If so, disable it.
    I would do this when you and a new RBS to the system, turn OFF the other RBS temporarily. Factory reset the newer RBS then sync it to the RBR using the sync buttons on the RBR first then RBS. It should sync correctly. Do this with the RBS is the same room. If it syncs correctly and appears in the RBRs web status page correctly, turn it off then place in it's remote location. Turn on all RBS and them them sync. I would do them 1 at a time.
    30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
