RV078
Jan 22, 2019Aspirant
Factory reset but now can’t login to router ssid
I’m really hoping someone can help me. I did a factory reset on my orbi, but cannot connect to the default SSID, as I no longer have the password that came with my system. Tried to log into orbi...
michaelkenward
Jan 22, 2019Guru - Experienced User
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See Labels.
