St3rMiN4ToR
Feb 27, 2019Tutor
Factory reset info
Hello, the factory reset in the GUI will reset both, router and satellite, or just the router? Thanks in advance.
Feb 27, 2019Guru - Experienced User
Just the router. If you log in to the satellite, you can reset it from there.
St3rMiN4ToR
Feb 27, 2019Tutor
Ok, I am logged into the satellite, where can I find the reset button?
Thanks.
- FURRYe38Feb 27, 2019Guru - Experienced User
Is there a Advanced selection some place? Possible the Satellite doesn't have a reset UI.
If it doesn't you'll just need to hit the reset button on the back.- Chuck_MFeb 27, 2019Mentor
There is no option to reset an RBR50 or RBS50 from within the GUI. That is purely a mechanical thing with the paperclip.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- ShotroundFeb 27, 2019Apprentice
from the router, what does Advanced - Administration - Backup Settings - Revert to factory default settings do?
