CaptainHook0
Apr 21, 2020Tutor
Factory reset my Orbi in bridge mode, now can't connect
My RBK53 system was working great--for about a week and a half and then became a disaster. It was dropping about 7% of packets and wreaking havoc on working from home. After several troubleshooting...
Apr 21, 2020Guru - Experienced User
Do you mean AP mode? Orbi doesn't support actual bridge or wireless bridge modes.
AP mode info:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
What is the Mfr and model# of the Internet Service Providers modem/ONT or host router that the NG router is connected too?
CaptainHook0
Apr 21, 2020Tutor
Yes, I meant AP mode. Orbi calls it “bridge mode” in the troubleshooting part of the app.
It is connected to a gigabit network switch which is wired into my network. I did connect it straight into the cable modem as well just to try it but no luck there either.
I found some sftp instructions to push the firmware on this forum but it doesn’t respond to the default IP anyway. The firmware was the latest, I tried rolling back to the previous version which worked fine on the satellites but not the router.
