Julie23269
Jun 12, 2017Follower
Factory Reset w/o Original Wifi Name and Password
Hi - I managed to lose the original wifi name and code that came with my Orbi, and now I need to return it to factory settings. Does anyone know how I can find ot what those codes are...? Or is ther...
peteytesting
Jun 12, 2017Hero
if you connect via ethernet after a factory reset it should just bring up the initial install page and you go from there
