browneyesblue
Feb 27, 2021Initiate
factory reset/security questions
I do not know the security questions and need to do a factory reset, help.
Feb 27, 2021Guru - Experienced User
What actual device do you have? You posted in the orbi forum and put c6250 in your signature.
You can go to netgear.com/support/
type in your actual model number and it'll take you to things like guides, manuals (has how to factory reset).
- browneyesblueFeb 27, 2021Initiate
Thank you, I did not realize I was in Orbi My apologies
