golfbridge
Dec 01, 2019Aspirant
fail to setup
I just bought a new system, tried to setup through ORBI app. It was successful only for split second, then back to offline. I had a RB50 before, it had same problem after a power failure, I was not...
- Dec 01, 2019
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Dec 01, 2019Guru - Experienced User
What modem are you connecting to?
Are you going modem------>router------>devices? or is there something else in the link?
Where in the process is it failing? You say it was successful for a minute and then back offline.
how do you know its offline? Are your devices connecting and then saying no internet? What exactly is going on?
have you tried going through setup using the browser and hardwiring to the orbi with a pc?
If this is the 2nd system with this issue, I'd probably be looking at the modem and cabling. Potentially you got 2 bad systems but more likely, something else was the original culprit.
golfbridge
I used the ORBI APP setup through my iphone, It went succefully but only for split second from online to offline.
From the ORBI app it tells you the staus, I was so happy to see it connected successfully, but next second it says offline again.
I am using ATT 5268AC. I still can get emails but only limitted internet access. I still can watch utube but not netflix!!!??
I will call my modem service tomorrow.
plemans wrote:What modem are you connecting to?
- FURRYe38Dec 01, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop - plemansDec 01, 2019Guru - Experienced User
Just like FURRYe38 explained. You're in a double nat. Follow the directions that were provided and it should work fine.
- golfbridgeDec 01, 2019Aspirant
Thanks, that is exactly what happened. My son recommand to use a app 1.1.1.1 to make the problem away.
But after you explained to me I understand better, Thank you again!!
- FURRYe38Dec 02, 2019Guru - Experienced User
Enjoy. :smileywink:
golfbridge wrote:Thanks, that is exactly what happened. My son recommand to use a app 1.1.1.1 to make the problem away.
