lnjustin
Apr 05, 2023Aspirant
Failed DNS Orbi
I keep getting failed domain name resolution errors, and they are really becoming problematic for me. I see there was some issues with Orbi systems a year or two ago that was allegedly solved with a ...
Apr 05, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you see this on? Mobile and PCs?
Did this just start happening or has been on going?
Be sure to check out NGs download pages or here in the forums for FW update information:
