bb0818
Nov 21, 2020Tutor
failed firmware update
I have an orbi RBR50 with RBS50 satelite. I purchased them some time ago. The firmware version in the firmware update page shows v1.2.0.6 (really old). It always showed "no new firmware version av...
- Nov 22, 2020
I was successful getting the router and satelites up to the current version. I'm going to lay this out so that if someone looks at it its all in one place. Thanks to FURRYe38 for the information. He came up with the fix(es). I'm just putting it together for the next guy.
Problem: Router (RBR) and Satellite (RBS) were at v1.2.0.6. When Satelite updated, would not talk to Router. Router would not accept update to v2.7.1.60 (said file was incorrect).
Steps to Solve
To get Satellite working again hard connected from computer to a port on the RBS. Computer was addressed 192.168.1.245 (had to be in 192.168.1.xx network). Pressed factory reset and waited until the top ring turned magenta (2 minutes or so) and then launched a web browser to 192.168.1.250 (the RBS automatically trys to come up on that address if it can't connect to the RBR). Uploaded v1.2.0.6 firmware (to get everything up to a working state).
Upgraded firmware in the following order:
RBR and RBS to v1.12.0.18 (the last of the v1 versions) Couldn't go to v2.0.0.74 from where I was.
RBS to v2.7.1.60
RBR to v2.0.0.74
RBR to v2.2.1.212
RBR to v2.7.1.60
Don't know if i needed to do all of them, but got from FURRYe38 couldn't go directly from v2.0.0.74 to v2.7.1.60. It all worked out, and I'm now fully up and connected!
Thanks again to FURRYe38@
bb0818
Nov 21, 2020Tutor
Thank you for your reply. I have the firmware, but I don't know how to get it onto the RBS. It does not show on the RBR, and as far as I can tell it doesn't have an IP address. I think I can upgrade the RBR to this version, but I'm clueless as to how to get it on the RBS. I hope you can help me.
Nov 22, 2020Guru - Experienced User
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
