Jokul
Nov 05, 2018Aspirant
Failed to connect google/Apple/etc. website with https
Chome browser failed to work as another ssl certificate returned to browser (the cert is with orbi keywords from 1-2 years ago). Could you please help to figure out how I can stop orbi trying to decr...
randomousity
Nov 05, 2018Luminary
So, I don't know that this is the issue, but it could be. With certain settings, the Orbi will return its own webpage intead of the one you requested. Some scenarios where this will happen is if you have access control enabled and are using a blocked device, if you have the traffic meter enabed and have reached your quota, if you have blocked sites or services enabled and try to access one, etc. So, I'd check all of those and confirm that none of them are the cause.
Other than that, could it be something with the Orbi VPN being enabled and somehow interacting in a bad way with the VPN you're using on your device?
