Jokul
Nov 05, 2018Aspirant
Failed to connect google/Apple/etc. website with https
Chome browser failed to work as another ssl certificate returned to browser (the cert is with orbi keywords from 1-2 years ago). Could you please help to figure out how I can stop orbi trying to decr...
Jokul
Thanks for the solution, I did all those yesterday, and was thinking the problem should be gone. And even turned off all unnessary service like parental control, vpn server, etc. Only the basic wifi feature was on.
It worked for last night. But the problem came back this morning.
After I reboot the router, it worked again.
I will be waiting for the problem happen again to capture the orbi SSL certificate returned to browser. (Chrome verifys the certificate is different from the google domain name)
And looks like this is the rootcause that all SSL connection fail. (a wrong orbi SSL certificate send back)
Nov 06, 2018Guru - Experienced User
Try a different browswer like IE11, FF or Opera.
I would also do a factoyr reset on the Orbi router and setup from scratch...You can also do a full re-load of the routers FW as well and see if this might help.
- JokulNov 06, 2018Aspirant
Thanks for all suggestions, I moved 2nd satellite closer (the signal strength was weak in past). Also another satellite was in sync status after main router reset to factory. Reset the satellite. Now both satellite are in good signal.
I renabled VPN/parental control. So far, it works for whole day.
Appreciate for all help! Thanks!
- FURRYe38Nov 06, 2018Guru - Experienced User
Good to hear. Hope it keeps working well. Enjoy. :smileywink:
