xiiaobai92
Apr 21, 2018Aspirant
Failed to download detention database @ QOS setup
Hi, I am trying to do the QOS setup on my orbi rbk40. When i tried to set automatic update performance database on router, it displays an error message "Failed to download Detention Database. Pl...
Apr 21, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem the router is connected too?
What version of FW is currently loaded on the router?
- xiiaobai92Apr 21, 2018AspirantThe modem I use is Zhone 2426 modem and router software version is V2.1.2.18
- FURRYe38Apr 21, 2018Guru - Experienced User
Is the modem/router bridged or running in router mode? This could be a problem if the modem is running in router mode. Having two routers on the same line is not recommended.
Try bridging the modem or use the DMZ on the modem for the Orbi routers IP address it gets from the modem.
- xiiaobai92Apr 21, 2018AspirantThe modem is provided by my ISP which gets the internet source using Fiber and connected to my orbi router thru rj45
