xiiaobai92
Apr 21, 2018Aspirant
Failed to download detention database @ QOS setup
Hi, I am trying to do the QOS setup on my orbi rbk40. When i tried to set automatic update performance database on router, it displays an error message "Failed to download Detention Database. Pl...
Apr 21, 2018Guru - Experienced User
Is the modem/router bridged or running in router mode? This could be a problem if the modem is running in router mode. Having two routers on the same line is not recommended.
Try bridging the modem or use the DMZ on the modem for the Orbi routers IP address it gets from the modem.
