klsmls
Apr 09, 2020Aspirant
Failure to get internet IP with Metronet Fiber ONT - Orbi Router RBR50v2
Power cycle modem. Power cycle Orbi. In all order. Factory reset. Netgear support. Nothing worked. My Orbi wifi router will no longer get a WAN (internet) IP from the Metronet Fiber ONT devi...
kgsmethers
Yes. I did a full factory reset and I’ve power cycled numerous times. Even after downgrading firmware I’m still having the connection issues
Apr 09, 2020Guru - Experienced User
So is the RBR getting an IP address from the modem or having connection issue to the internet?
- kgsmethersApr 09, 2020AspirantI’m honestly not sure. How would I check? If I plug a computer directly into the modem I have great connection
- FURRYe38Apr 09, 2020Guru - Experienced User
Log into the RBRs web page at 192.168.1.1 with a web browser and check the Advanced Tab Home page. Status on the WAN port will be seen here.
What FW version are you using now?
- kgsmethersApr 09, 2020AspirantHere’s everything as is.
