klsmls
Apr 09, 2020Aspirant
Failure to get internet IP with Metronet Fiber ONT - Orbi Router RBR50v2
Power cycle modem. Power cycle Orbi. In all order. Factory reset. Netgear support. Nothing worked. My Orbi wifi router will no longer get a WAN (internet) IP from the Metronet Fiber ONT devi...
Cficklin31
Apr 14, 2020Tutor
So far so good. Do you think there is an issue with the Netgear NTP causing issues with network authentication on Metronet?
SW_
Apr 14, 2020Prodigy
It's only a suspicion on my part, hence the request for an update. I can't really test/verify my suspicion because my Orbi is currently running in AP Mode. If NTP/time server is not working properly, it could cause problem for Orbi/DHCP when it's time to renew its WAN IP address because DHCP relies on working NTP/timer for IP address renewal.
