gav2150
Feb 09, 2022Aspirant
Faulty RBR50? Green power light, completely unresponsive.
Had a bit of a weird one this week with my RBR50 and I'm hoping that it's not completely fubar'd Got up one morning to find that the wifi had gone off and the RBS was showing a solid magenta ligh...
Feb 09, 2022Guru - Experienced User
Try nmrpflash:
https://github.com/jclehner/nmrpflash
If this still fails and you swapped power adapters and the RBR doesn't recover, I would presume the RBR is bad and needs replacing.
gav2150
Thanks, I'll give that a try and see how I get on. Given it's not detecting a network connection I'm not overly hopeful, but I'm completely out of ideas.
- jhcollierApr 12, 2022Aspirant
Same trouble here. I have attempted the TFTP route (192.168.1.1 will not ping) and the 30-30-30 method of trying to reset the device. Ended up buying a replacement from Amazon for $45.00 but it won't be here for a week. đ
Any other ways of resetting that anyone has found?
Thanks in advance.
J.
