KurtL
Dec 14, 2016Aspirant
Feature? Auto on and off time
My wife is convinced the WiFi signals in the house are disturbing her sleep. Does the Orbi have a feature to auto shut off the wifi radios say at 11PM, and then turn them on again at say 7AM?
yes it does , but to prove a point just tell her you have switched it off for a week and see the response , then have it off for a week and tell her you are doing a 2 week trial
its called blind testing
i dare say she wont see no difference
- KurtLAspirant
Can you point that feature out to me in the manual? I'm not seeing it. I see a schedule for blocking sites or services, but not to actually turn the radios off. Thanks...
- DarrenMSr. NETGEAR Moderator
Hello KurtL
You can only shut off internet connection to certain devices you can not turn the wifi off completely via a schedule you would have to log into the router to do that.
DarrenM
