Caleb73
Oct 19, 2021Aspirant
Feature request: Disable Wireless Backhaul when wired
I'd like to request a feature that disable the wireless backhaul when the satelites are wired into the router. I have a lot of wifi congestion and having trouble getting reasonable coverage on some ...
- Oct 20, 2021
One other reason that wifi backhaul cant' be disabled is that if something happens to the ethernet connection to the RBS, the RBS will fall back on wireless backhaul connection to maintain operation. The wireless backhaul is one 5Ghz and won't effect anything on 2.4Ghz.
Oct 20, 2021Guru - Experienced User
