itGeeks
Sep 26, 2016Apprentice
Feature Request: Orbi Satellite Ethernet Backhaul
As good as Orbi looks on paper I don't understand Y you would cut yourself so short and not support Eithernet backhaul for the satellites, I have 5 locations needing a system like this but without su...
- Apr 26, 2017
Let me acknowledge that our customer base has been clamoring for this feature for a while, and we are trying to be responsive to their needs. To provide context on why it's taking a while to get it out, during the first quarter, the Orbi Engineering team was focused on bringing out the two new products (RBK30 & RBK40) to market. Now that it's accomplished, we're actively working on bringing this feature and a couple of other interesting, market-requested features to you.
Orbi Product Team
Retired_Member
May 29, 2017"We acknowledge some disconnect issues"... Well we better go mark all those threads as solved also!
- altheaJun 05, 2017Guide
I'm confused. I have a separate structure that requires a satellite Ethernet connection. Is "backhaul" only a function of the satellite or does the router itself make this not possible. I was told by support that I can use my existing Airport Express via Ethernet but I am having a heck of a time getting it to work. Every time I try to update the settings on the Airport Express to extend my Orbi wireless network it disconnects everything on my network from the internet (wireless signal still works but the Orbi is not picking up the internet from my gateway). I'm thinking of trying a different wired access point. If it's just a matter of the satellite not supporting ethernet, shouldn't it work if I just hook up, say, a Netgear WAC510 or any other access point that provides an ethernet port for connecting to a router???? If so, is there any disadvantage to doing this?? Would this create a different SSID for the wired access point?? (that would be a deal killer).
I've been pulling my hair out over this for over a week. I would be ecstatic if someone knowledgable could clear this up for me.
Thanks.....
