itGeeks
Sep 26, 2016Apprentice
Feature Request: Orbi Satellite Ethernet Backhaul
As good as Orbi looks on paper I don't understand Y you would cut yourself so short and not support Eithernet backhaul for the satellites, I have 5 locations needing a system like this but without su...
- Apr 26, 2017
Let me acknowledge that our customer base has been clamoring for this feature for a while, and we are trying to be responsive to their needs. To provide context on why it's taking a while to get it out, during the first quarter, the Orbi Engineering team was focused on bringing out the two new products (RBK30 & RBK40) to market. Now that it's accomplished, we're actively working on bringing this feature and a couple of other interesting, market-requested features to you.
Orbi Product Team
lovingbenji
Jun 28, 2017Star
No specific date ?
Google WiFi here I am ...
myrison
Jun 28, 2017Guide
I would also really like to see wired backhaul. I live in a large home and just cannot place the router in the center point in the home (the Kitchen/living room, which are off limits for tech gadgetry). As a result, the router on one edge of the house cannot reach the other side, no matter how many satellites I use.
However, the whole house is wired, so if they were able to communicate via backhaul, I could cover all areas easily.
Unfortunately I'll have to return mine until the feature shows up as the setup isn't usable for me without it.
- GabePaulJun 28, 2017Initiate
That is exactly the same situation with our home. I like many of the features of the Orbi, but will not use it without the Ethernet backhaul.
- st_shawJun 29, 2017Master
myrison wrote:However, the whole house is wired, so if they were able to communicate via backhaul, I could cover all areas easily.
If your whole house is already wired, a far better soulution than Orbi or any "mesh" system is to install a few wired access points.
- myrisonJun 29, 2017Guide
Agreed, and that's actually what I have now (prior to purchasing the Orbi).
However, I liked the idea of the simplicity of the Orbi using a single SSID with higher speeds. It so far generally delivers the higher speeds, but the coverage is actually quite a bit worse, so I'll be switching back to the multi-AP setup I had prior.
