djaesthetic
Nov 03, 2017Tutor
FEATURE REQUEST: Separate Access Control for Guest / Regular Networks
I just deployed my first Orbi (RBK50) system and loving it. On Firmware v2.0.0.74. So far I've come across only one issue I'd love to see addressed in a firmware update. I have Access Control ena...
AmitR
Nov 10, 2017NETGEAR Employee Retired
Can you help me understand better what you're trying to do. Let me type up what I think you're trying to do and perhaps you can comment on it? You basically want a 2nd order of security on the main network above and beyond the password.
- If on Guest Network, anyone with password can join.
- If on Main network, would it suffice if you got a notification if a device joined? That way you can either block it or take some other action against it?
Do you really need it to be MAC filtering?
Orbi Product Team
