sohammistry95
Jun 06, 2018Star
Feedback After Updating to V:2.1.4.16 on RBK40 & Xbox issue
I'm very pleased to say that NEW V 2.1.4.16 has bring an siginificant upgrade and fixes on my RBK40 Orbi router. It fixes alots of bugs, connection drop, intermidiate connection, no Internet connecti...
Jun 06, 2018Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4ghz and any unused channel on 5Ghz.
Any other wifi neighbors near by? If so, how many?
Can you connect your xbox one up via LAN cable and test speeds?
Disable MIMO, Daisy Chain and Fast Roaming. You can leave beamforming enabled.
What is the distance between the xbox and router or satellite?
Where do you have the xbox connected too? Router or satellite?
Was a full reboot performend on the Orbi system. Power OFF for 1 minute then back on after upgrading FW?
- sohammistry95Jun 07, 2018Star
Thanks for replying.
I have try switching different channels on both Ghz but nothing helps.
I have 15+ nghbors wifi nerby.
I can't connect my xbox hardwire because it's not possible. I have my xbox in living room & router game room.
My xbox one is connected to satellite and its about 240ft away.
Do you think it's problem either with Xbox One or Orbi Router hardware???
- tsigJun 07, 2018Luminary
- FURRYe38Jun 07, 2018Guru - Experienced User
240feet? You sure about this? :smileysurprised:
What channels are you neighbors using?
- sohammistry95Jun 19, 2018Star
Yes! The xbox is about 250ft away from satalite downstair & xbox is about 150ft away from Router in middle of the house upstiars.
My neighborhoods is using random wifi channals. Take a look at screenshots.
Now we are started to notice slow response time, slow loading time or sometimes wifi doesn't work and it just keep loading. Can you guys help me on that? * I have power cycling entire Orbi System + ISP modem but seeing little improvement but problem comes back. The problem started after couple weeks later since updating to V 2.1.4.16 * I've try changing channels but nothing helped.
