sohammistry95
Jun 06, 2018Star
Feedback After Updating to V:2.1.4.16 on RBK40 & Xbox issue
I'm very pleased to say that NEW V 2.1.4.16 has bring an siginificant upgrade and fixes on my RBK40 Orbi router. It fixes alots of bugs, connection drop, intermidiate connection, no Internet connecti...
goldbondx
Aug 17, 2018Apprentice
I continue to have random drops on both an Xbox one-s and Xbox one x. Distance to base is less than 30 feet with open 2nd floor. I don't feel the range is anywhere near advertised based on my IoT issues which we're non-existent with my old Asus router. Ring basic and pro have random connectivity issues. I have tried resets, spot beam changes and other options with no success. I am not happy with this product at all.
Aug 17, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
30 feet starting is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
