Yld2rob
Feb 05, 2017Luminary
FINALLY got the ORBI not to drop connection!
OK. As some of you know, I have had nothing but disconnects from the Orbi system for the last 2 months (I even exchanged the Orbi system for a new one to ensure I did not get a defective unit). I hav...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
st_shaw
Feb 05, 2017Master
Good finding. May explain why many people have no issues. I'm in AP mode myself with no problems.
Hopefully the info will help Netgear find a solution.
- superben79Feb 05, 2017Apprentice
Hi I am running orbi in router mode, connecting to the Fios router with wifi off. I am experiencing some slow down and disconnected as well.
So so I can just change the orbi from router mode to ap mode? Can I continue to use thr orbi for wifi with the same ssid/pwd as before? What do I gain and lose if I switch to the ap mode?
- st_shawFeb 05, 2017Master
superben79 wrote:Hi I am running orbi in router mode, connecting to the Fios router with wifi off. I am experiencing some slow down and disconnected as well.
If you still have the FiOS router it's usually best to run the Orbi in AP mode anyway. You lose the router functions of the Orbi, but they aren't anything special, and your FiOS router will handle routing.
- jxrxmeMar 04, 2017Star
I can't confirm this. I use my Orbi in AP mode and get frequent disconnects. But only in one specific room, elsewhere it just works perfect.
