Yld2rob
Feb 05, 2017Luminary
FINALLY got the ORBI not to drop connection!
OK. As some of you know, I have had nothing but disconnects from the Orbi system for the last 2 months (I even exchanged the Orbi system for a new one to ensure I did not get a defective unit). I hav...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
saronian
Feb 06, 2017Star
That's how I have mine setup with sonic.net service using a Pace 5268ac modem/router.
Pace WiFi off, Orbi on AP mode. No problems with MacBook Pro, Mac mini, Apple TV, iPad Pro, iPhone 7, TiVo Roamio+Stream.
WiFi transfer speeds are 45+ Megabytes per second between MacBook Pro and Mac mini. WiFi Tx Rate shows as 780 Mbs.
thebishop
Feb 07, 2017Apprentice
It would be great if it was nailed down to that (I am running in Router mode and having problems with dropped Wifi connections as outlined in another thread) - then Netgear engineering would have an easier time fixing it.
