Yld2rob
Feb 05, 2017Luminary
FINALLY got the ORBI not to drop connection!
OK. As some of you know, I have had nothing but disconnects from the Orbi system for the last 2 months (I even exchanged the Orbi system for a new one to ensure I did not get a defective unit). I hav...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Ralph052
Jun 22, 2017Guide
Hey petey ... you're not the only one. No issues outside of the need to manually update firmware at the beginning out of the box. Other than that ... rock solid here.
- peteytestingJun 22, 2017Hero
Ralph052 wrote:
Hey petey ... you're not the only one. No issues outside of the need to manually update firmware at the beginning out of the box. Other than that ... rock solid here.hi ralph
and this seems to be the issue , we have 2 camps
those that the orbi works perfectly from day 1
those that have nothing but issues
it is my opinion thatthe dev team should look at why we have such good orbi setups and work from there rather than look at the worse case and figure it out rom there
i would rather have a fast car and make the rest as fast as it than have a slow car and try and make it fast
bit of nonsense logic but im my mind it works
pete
