Yld2rob
Feb 05, 2017Luminary
FINALLY got the ORBI not to drop connection!
OK. As some of you know, I have had nothing but disconnects from the Orbi system for the last 2 months (I even exchanged the Orbi system for a new one to ensure I did not get a defective unit). I hav...
- Jul 11, 2017
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
Ralph052
Jun 22, 2017Guide
If there's data the team needs for the "no issues" camp ... I'm open to help.
Jamessimmering
Jul 10, 2017Star
I am one of the people who has issues almost from the beginning. Out of the box it worked great for about 24 hrs. I suspect (But cannot confirm) that it updated the firmware. From then on it has been repeatedly dropping connection. I have tried all the fixes listed:
Movng the satellite, Cutting down on the 2.4 ghz power, turning on and off beam forming and MU-MIMO, restarted the router countless times. I am not getting ready to try it in AP mode.
I had a ticket out with NetGear but they closed it without resolving it.
does anyone know where the beta software is that is supposed to fix this issue?
Jim
- DarrenMJul 11, 2017Sr. NETGEAR Moderator
Hello Everyone
Thanks
DarrenM
