Alanyako
Jul 21, 2019Aspirant
Finding hard time connecting to internet
The router can’t connect to the internet it’s staying offline Nz Vodafone fibre
ekhalil
Jul 21, 2019Master
- What type of model do you use to connect to the fibre?
- Is Orbi in Router or AP Mode?
- Can you reach to the Orbi web GUI? If yes what do you see under >> ADVANCED >> ADVANCED Home >> Connection Status ?
Alanyako
RBK53|Orbi AC3000 Tri-band WiFi System
That’s the model
That’s the model
