Alanyako
Jul 21, 2019Aspirant
Finding hard time connecting to internet
The router can’t connect to the internet it’s staying offline Nz Vodafone fibre
Alanyako
RBK53|Orbi AC3000 Tri-band WiFi System
That’s the model
That’s the model
ekhalil
Jul 21, 2019Master
That’s the model
What ISP Modem do you use?
- AlanyakoJul 21, 2019AspirantVodafone fibre
- FURRYe38Jul 21, 2019Guru - Experienced User
There a router built into this Vodafone unit by chance?
- michaelkenwardJul 22, 2019Guru - Experienced User
Many ISPs insist on providing modem/routers, and all too often they are crippled in that they do not make it easy to put these modem/routers into bridge (modem only) mode.
That is on reason why a lot of people use Orbi routers in AP mode.
