mith_it
Jun 19, 2018Luminary
Finding out ideal radio Tx
I have an RBK53, but I have to say it covers my home very well, in fact too well. I found that often I am getting decent wifi performance while being connected to the farthest satellite/router. I am t...
- Jul 03, 2018With not too much fiddling I found that I can enable debug on both the router and satellites. I can then telnet to any device and manually set wl_tpscale for 2.4Ghz and wla_tpscale for 5ghz.
The devices take the setting immediately as I can see the change the router's Web UI. I haven't tested if it ACTUALLY changes the TX. At this point I'm still trying to figure out the ideal configuration for me.
I also have not tried rebooting the devices.
Jun 20, 2018Guru - Experienced User
Since there isn't any power settings on the satellite, you'll have to play around with the power settings on the router. I presume if you reduce the power on the router, satellites may need to be placed a bit closer, which you'll also need to play around with there placement if you do this. You'll need to check the status on the connection seen on the router. Good or Poor and base your adjustments of that. Then check your devices to see how they are connected by doing some point to point connection and speed tests at various places around your home.
mith_it
Jul 03, 2018Luminary
- FURRYe38Jul 04, 2018Guru - Experienced User
You can also change power settings under Advanced tab/Advaced Settings/Wireless.
I would reboot everything and test...
Good Luck.
