mith_it
Jun 19, 2018Luminary
Finding out ideal radio Tx
I have an RBK53, but I have to say it covers my home very well, in fact too well. I found that often I am getting decent wifi performance while being connected to the farthest satellite/router. I am t...
- Jul 03, 2018With not too much fiddling I found that I can enable debug on both the router and satellites. I can then telnet to any device and manually set wl_tpscale for 2.4Ghz and wla_tpscale for 5ghz.
The devices take the setting immediately as I can see the change the router's Web UI. I haven't tested if it ACTUALLY changes the TX. At this point I'm still trying to figure out the ideal configuration for me.
I also have not tried rebooting the devices.
mith_it
Jul 03, 2018Luminary
Jul 04, 2018Guru - Experienced User
You can also change power settings under Advanced tab/Advaced Settings/Wireless.
I would reboot everything and test...
Good Luck.
