jjodod1
Jul 14, 2021Aspirant
FIOS and Orbi RBR40
Hi Folks, I just switched from Xfinity (with a modem) to FIOS. I have outstanding speed at the router, but >65% drop off throughout the house. My configuration is (1) Orbi RBR40 and (2) RBS20 sat...
Jul 14, 2021Guru - Experienced User
Has a pull power OFF of the ISP modem/ONT and the RBR and RBS for 1 minute then back ON been performed?
14 feet between the RBR and the 1 RBS is too close. 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
