Gellie's avatar
Gellie
Fios Quantum router with orbi RBR50/RBS50
I have the Fios for internet only. Should i turn of the WiFi on the fios router and just use to orbi? Or should I use the Fios as router and put the Orbi in AP mode? Thanks
  • FURRYe38's avatar
    AP mode would have more performance as it woudn't have to process as much data as if it was in router mode.
