Gellie
Jul 25, 2019Aspirant
Fios Quantum router with orbi RBR50/RBS50
I have the Fios for internet only. Should i turn of the WiFi on the fios router and just use to orbi? Or should I use the Fios as router and put the Orbi in AP mode? Thanks
- Jul 27, 2019
AP mode would have more performance as it woudn't have to process as much data as if it was in router mode.
Gellie
Thanks. Before I got your reply I disabled the Wi-Fi on the Fios router and enabled router mode and daisy chain on the Orbi. Seems to be working. Is this not optimal ?
Jul 25, 2019Guru - Experienced User
If the router portion of the FIOS router is running then your in a double NAT condition which isn't recommended. To help this, find the FIOS routers DMZ and input the IP address the Orbi router gets from the FIOS router into the FIOS routers DMZ. DMZ may also show as IP Pass-through or Exposed Host as well.
If you only have one RBS placed, Daisy Chain should be disabled. It's only need if you have two or more RBS placed out in a line from the RBR.
- GellieJul 25, 2019AspirantThanks again. But I’m afraid what your asking me to do is a bit above my pay scale. Yes running 2 RBS. Maybe I should turn back on the Wi-Fi on the Fios and run Orbi in AP mode?
- FURRYe38Jul 25, 2019Guru - Experienced User
Yes, if thats easier, configure AP mode on the Orbi. Please disable ALL wifi radios on the FIOS router.
YOu'll have to play with Daisy Chain. If you place the RBS in a star formation out from the RBR, then Daisy Chain can be disabled. IF the RBS are in a line out from the RBR, You can enable Daisy Chain. This tells the RBS to piggy back of the other.- GellieJul 25, 2019AspirantTY. How do I disable all Wi-Fi radios on he Fios? Didn’t I do that already by disabling Wi-Fi? I have the Orbi router on the basement level, on satellite on the first floor and one on the second floor. Obviously not in sight of each other. Should I disable the daisy chain?
