Gellie
Jul 25, 2019Aspirant
Fios Quantum router with orbi RBR50/RBS50
I have the Fios for internet only. Should i turn of the WiFi on the fios router and just use to orbi? Or should I use the Fios as router and put the Orbi in AP mode? Thanks
- Jul 27, 2019
AP mode would have more performance as it woudn't have to process as much data as if it was in router mode.
Gellie
I’ll give it a shot when I get home. TY
Jul 25, 2019Guru - Experienced User
:smileywink:
- GellieJul 26, 2019AspirantOk so I think Im pretty much good to go. Orbi in AP mode with daisy chain on. What features or enhancements am I missing by not using router mode? Thanks.
- FURRYe38Jul 26, 2019Guru - Experienced User
The router of course, Traffic Meter, Circle and Armor security apps and access controls.
Enjoy.
Yes. But in terms of performance, speed ,distance is AP mode a compromise?
- FURRYe38Jul 27, 2019Guru - Experienced User
