Chi7
Sep 28, 2018Star
FIOS setup - No Caller ID
Hello. New user here. Making the switch from the AMPLIFI HD to the Orbi. I set it up exactly how the AMPLIFI was by really just replacing the routers and leaving the Ethernet cables in place, Orbi ...
Sep 28, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Any router built in here by chance?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Do wired devices get these services when connected thru the Orib or is it just wireless devices?
- Chi7Sep 28, 2018Star
It's the actiontec MI24WR, something like that, Rev. 1. it's the FIOS issued MoCa router.
No wired devices, everything is wireless.
- FURRYe38Sep 28, 2018Guru - Experienced User
Does the Actiontec have a DMZ? If it does, set up a reserved IP address ON the Actiontec router for the Orbi router. Then place this IP address into the DMZ on the Actiontec. You might reboot the Actiontec and Orbi once this is done, Then test your services.
